SMB - Subscription required!
asa1
SMB User
Got a few users setup on 3CX SMB and when I try to login to the portal now, it says Subscription Required and gives me two options: Create Subscription or Delete Account.
It's a very basic setup so can't see that the account has exceeded the limitations of the free offering, how can I find out why it now requires a subscription/reset the requirement to continue using the free tier?
The blog post says:
With the advent of 3CX Basic Edition we will begin scaling back 3CX SMB Free. This means in the not-too-distant future the SMB license will be downgraded to Basic. Important to note, if you’re using IP phones you will no longer be able to rely on the free 3CX SMB edition.
Which is a worry if you want to use SIP phones (if I'm reading this correctly)?
Correct that will change…to the equivalent of 4SC Basic Free.
Isuru Eranga
