Solved SMS Configuration is Disabled in 3CX
James S
New User
When I attempt to press "OK" when configuring SMS I get a message, "Feature available in 3CX Professional and Enterprise Editions" and it does not allow me to save the settings. I have the Professional edition. Any ideas?
@James S can you try again please ?
As I can see you have a Trial Key and you have upgraded to Free Pro.
@James S one question please are you logged in as super admin or as user with admin rights ?
@James S can you login as Super Admin and let me know if you have the same issue ?
@James S would you mind PM me ?
Create a test extension with full admin rights, give me credentials to login to your machine, i will make some tests and then when tshoot is done you can delete this extension totally.
So make a test extension, send welcome email to yourself and send me the credentials please.
Then delete it.
@James S as per our private chat, there is no issue on the PBX side as when I logged in with Chrome and made a TestSMS config with random API key all was fine.
Now I can't say what Chromium-based Edge sends on the background for the first time but since now you are also able to set this up, as we discussed this thread will be marked as Solved.
Have a nice day !!
GP Concepts
