SMTP Email for Voicemail
Hey, yes it did. What's your e-mail address, I can e-mail you what Alex sent me.
smtp authentication and ssl
Great. Thank you. Are you using SSL?
I will PM my email to you.
smtp authentication and SSL
Thank you ESS. I now able to use our smtp server with authentication. Although as you indicated it will not work with TLS (SSL).
Mark
Thank Alexander, he is the one who fixed it :)
was having the same issue and removed the username & password and it worked fine... strange because i need them for outlook.
Hi shuey227,
Since your SMTP server need not smtp authorization.
Regards,
Does anyone know if you can send SMTP emails using SSL ? My ISP has blocked port 25 and is using 465 and requires an SSL connection.
Getting Started - Admin
deanhbs
Get 3CX - Absolutely Free!
3CX
