Snom D717 Provisioning Issue
balu
  • 3CX Version, Enterprise Annual 16.0.676
  • Server OS Debian GNU/Linux 9
  • Is the 3CX Server Hosted and where? Datacenter as VM (KVM based)
  • IP Phone Make/Model/Firmware SNOM/D717/10.1.46.16
  • Provisioning Method: SBC
We're noticing the same Issue as in https://www.3cx.com/community/threads/bug-snom-d745-template.69739/#post-307628
Also, on each reprovisioning, the configurations for audio and ringtones are reset to default.
When can we expect a new working template?
Kind regards,
daniel
Hi balu,
Please give an accurate description of your issue as you experienced it (ignore the other post for now). You can provide a screenshot too if you like to show us what you see on the phone screen.
Basically we recognizing the following issue:
The 3CX-Logo isn't shown anymore, because SNOM changed the way, it displays the Background-Picture (doesn't need to be resized anymore) -> For us not bad, because we're using already our own logo.
Also, the on-screen buttons on the left show its screen-informations only when there is a active call:
Without call:
13558
With Call:
13559
Last but not least: If you change your Audio-Settings (Volume, Ringtone,...) these changes are replaced by the default one, at the next provisioning.
The new Snom template should be published now and fixes the BLFs on the right hand side not appearing. There will be no default logo provisioning in this edition but if you use Enterprise Edition you can upload your own custom logo via the management console.
I would suggest to update your PBX to V16 Update 4 which is now also officially published.
Thanks a lot.
With all due respect. In the last versions there were so many bugs (and releasing a phone firmware without a template check is part of it) that I will wait at least half a year...
3K8iMGWviZ
