SNOM D8XX - No integration yet ?
Arthur.b
Platinum Partner
I'm currently configuring à new 3CX with the new D8XX series (D862 & D865) but i don't see the model the list of phone in the 3CX admin console....
There any news about this new models ?
There was a webinar with Greg Garett the 09.14.2022
Hi Arthur,
Those models are in our future plans, keep an eye out for our blog posts.
Reactions: Arthur.b
Hi, since update update 7 you can use snom D862 and D865 ad router phone (sbc). But what's the procedure? I think SIP trunk > add new SBC. And then go to the snom phone Security > advanced and there set SBC to on and enter the SBC config file URL? I tried https://fqdb 3cx/sbc/Authentication KEY ID but I receive the error 'SettingsService::Set, setting is not found!'. Phone has latest firmware (10.1.141.13)
I was totaly wrong. Here I've found the solution: https://www.3cx.com/docs/manual/ip-phones/
Just one question, where can I found the 8-digit one-time PIN? Because I didn't receive a popup with the pin.
You were using update 7 so you will not need to type a PIN.
Just do all the actions needed from the 3CX end, and factory reset the Snom.
It will take a bit of time to contact the server and configure itself, might do a couple of reboots. Just needs a bit of patience :)
Reactions: ArneDery
Thanks, that works. He asked for login and password, but when you wait, the phone will provision. Thank you very much
Stephan Eusebe
