Snom M700 no Automatic provisoning
Roger Hess
I have a problem with the M700. I created it under FXS / DECT with the Macadresse. The 3cx is in the cloud and the phones are connected via SBC controller. But unfortunately, the M700 does not connect automatically. The cfg file is created. I can download that. Have already reset the M700. Other phones work.
Yes this works, can also register the mobile phones and make phone calls. But he does not show the 3cx phone book, but the link is registered in the base station, I can also download the phone book.
Hello @Roger Hess
As mentioned in the guide M devices can only be provisioned using the manual method.
Step 3: Provisioning a snom M base station
snom M-series can only be provisioned using the manual provisioning method. The general howto is outlined for a local LAN setup here: Snom DECT Series Manual Provisioning
Also you need to disable the "SSL Transport and Ciphers" option under the security options of the PBX.
Thanks for the information. I'll try again tonight.
Hello @Roger Hess
Thanks so it works!
Glad we could assist
jmarshall
