Solved SNOM PA1 not showing up in 3CX
Shane Farmer
I bought two SNOM PA1s on Amazon. The both show as PA1s in their respective interfaces, but one shows as snom300 in my DHCP logs. The issue is that the "snom300", also doesn't show up in my 3CX console. They both got on our Voice VLAN using LLDP/DHCP. I updated both to 8.7.5.75 firmware which is what 3CX supports according to their list.
This is my SNOM post:
https://helpdesk.snom.com/support/discussions/topics/6000057871
This is the first time I have used these devices. Working on setting up multicast paging.
Same network, yes. Same VLAN. I saw that first link, but missed the manual part. I'll give that a try. Thank you!
That did the trick. Thanks for the reply!
Reactions: YiannisH_3CX
GP Concepts
