Solved SoftPhone App Accounts
DrainBamaged
Forum User
It appears as if the number of accounts I can have on my softphone has been reduced to six entries. If I add a new config, one of the existing ones drops off.
As I had ten extensions for fault finding our offices, this is wonderfully inconvenient. I used to have all of them on there so I'm not sure when this kicked in, but please put it back to at least ten extensions.
Today
2020
You may close this ticket. An uninstall and reinstall of the softphone cleared up the issue. Something got corrupted.
Cheers.
Roman Mazur
