Solved [SOLVED] Upgrade failed (16->18)
romkus
Can anyone assist me with this failed upgrade?
I don't find anything helpful from the similar threads.
Thank you!
Hi @romkus,
This would be the reason why the upgrade aborted:
Does it mean, if I delete it, the upgrade should commence? Or do I now need to reset it somehow?
I'd try and move it out of the sources.list.d folder without deleting it first and trying to run it again.
ok, after moving the file out, the upgrade wen through.
Thank you very much!
Reactions: VasilisV_3CX
Glad to hear it @romkus! Feel free to open a new thread if you require any further assistance or information.
mazet
