Anonymous
Re: Incoming Calls
That's wierd that you can make calls but not recieve them.
Disabling the registration is done in the 3CX gateway setting, which you have done correctly.
What happens when you make an incomming call? Silence?
I have found that any changes that I need to make in my SPA400, I had to powercycle it not just reboot it for the changes to take effect. Have you tried that?
Also, are your phones registered because if they are not it will just go to the voicemail of the phone.
Brian
http://www.jaydien.com
nanees said:Hi Brian,
First off thanks for the setup help so far and posting this information .
I configured my gateway (SPA400) 192.168.104 using the setting you posted from you screenshots:
I can get outgoing calls to work just fine , however , I get no incoming calls . I dont know its a problem on the SPA400 end of the 3CX.
In a nutshell, i've configured the Gateway and Line Settings to exactly mirror yours in 3CX , the same goes for the SPA400. I changed all the FXO port Id's to match the internal numbers on my 3CX line.
Line 1 Internal Number = 10000
FXO Port ID_1 = 10000
You mentioned something about disabling the registration for the FXO Ports, is this done in the SPA400 ? I already disabled registration for the gateway setup in 3CX.
Here is the log when I make an outgoing call:
11:35:38.906 StratLink:nHangUp Call(C:9): got Hang-Up from Ext.120; reason: BYE
11:35:24.812 CallLegImpl:nConnected Established media channel for Ln:10000@SPA400: remote=192.168.1.104:10002; local=192.168.1.105:16432
11:35:24.796 StratInOut:nConnected Call from Ext.120 to Ln:10000@SPA400 is established
11:35:24.796 CallLegImpl:nConnected Established media channel for Ext.120: remote=192.168.1.105:16432; local=192.168.1.104:10002
11:35:21.500 CallConf:nIncoming Incoming call from Ext.120 to sip:[email protected]
Incoming Call: For some reason I get no log in 3Cx for any incoming call.
Any help is appreciated, my email is [email protected] , if you have one as well I can send you my config screenshots
Thanks !
Brian
