IT Heights Customer Joined Nov 26, 2023 Messages 16 Reaction score 0 Dec 19, 2023 #1 Can we filter or stop some of these Spam calls?
NicholasP_3CX Support Team 3CX Support Premier Customer Advanced Certified Joined Apr 25, 2014 Messages 2,487 Reaction score 2,357 Dec 19, 2023 #2 You can add numbers into the "Number Blacklist" V18 Management Console > Security > Blacklisted Numbers Click Add Add the number you wish to block, then click "OK" V20 Admin Console > Advanced > Caller ID Blacklist Click Add Add the number and click OK Reactions: IrinaP_3CX and Charles_3CX
nowak68 Bronze Partner Advanced Certified Joined Oct 11, 2019 Messages 43 Reaction score 4 Feb 23, 2024 #3 Hi , I have the same problem . Is it possible to block a range of numbers ? 31332096614 to 31332096620 per example or anything that starts with 31332096 . What`s the proper way to do this ? Regards , Harry
bitn2 3CX MVP Platinum Partner Advanced Certified Joined Mar 25, 2020 Messages 2,674 Reaction score 1,590 Feb 23, 2024 #4 31332096* should work for you Reactions: grizly and IrinaP_3CX
nowak68 Bronze Partner Advanced Certified Joined Oct 11, 2019 Messages 43 Reaction score 4 Feb 24, 2024 #5 bitn2 said: 31332096* should work for you Click to expand... Thanks
