Speed dial with PIN code.
AdamChi
I am still on 15v.
I have a service I use that tracks my calls with my CRM. In order for the tracking to properly take place, I need to call an access number, enter my PIN and then dial the actual number for the person I want to get a hold of.
Is there a way to configure this so instead of going through the process of dialing the access line and then entering the code I will just dial *5 or similar and then the number I want to dial?
As far as doing this in 3CX you can configure two speed dial buttons, the first for the access number and the second for the PIN.
As far as doing this natively on the phone you'd have to see if your phone supports pauses or macros to to add a delay in the dial string for the access number to answer. This is phone model dependent. Here is an old thread on how to do this on Yealink phones:
http://forum.yealink.com/forum/showthread.php?tid=207&pid=64234&mode=threaded
hughesdouglas
