SQL INTEGRATION - unanswered outgoing calls
alexis41818544158
Platinum Partner
Good morning everyone,
I have an installation that has CRM integration to MySQL active that I use to send data via api from the call log.
All calls are correctly sent to the database EXCEPT the unanswered outgoing calls. Why?
This is the query I use in the Call Journaling SQL Statement
INSERT INTO calls (calltype, contactnumber, calldirection, queueextension,agentextension, duration, calldatetime) VALUES (@CallType, @number, @CallDirection, @QueueExtension, @Agent, @Duration, DATE_FORMAT(@CallEstablishedTimeUTC, '%Y-%m-%dT%H:%i:%s%Z'))
How can I also send the unanswered outgoing calls?
You need to enable verbose logs, reproduce the issue, and then check the 3cxSystemService.log so you can understand why this is happening.
MySqlConnector.MySqlException (0x80004005): Parameter '@CallEstablishedTimeUTC' must be defined.
The problem was on the use of this variable, rightly if the call is not established it does not have a start date.
I solved it using the variable @CallStartTimeUTC.
You can use a different SQL query for established calls and not established calls. You will need a custom template, but doable.
