SSL certificate 3CX server on premise , not updated
toby_afr
Hello all
We have a 3CX server v 20 with an external adress created during the installation (https://caa.3cx.sc/) .
Last year the SSL certificate (i think) was renewed automatically. However now since october, this certificate is now expired.
Is there any possiblity to launch an automatic renewal or do i have to do it manually. If so , is there any easy step by step to follow
to arrange this .
Best regards
Toby
Is it an 3cx fqdn or your own?
its a 3CX fqdn It was created automatically when we installed the system two years ago
/Toby
Where is it installed? Which version? Firewallcheck ok?
Im bumping this threat. In fact, the problem was never solved as we are only running it internally. However i saw now that in v20 i will not be able to access anymore. The server is caa.3cx.sc . Its created with the 3CX setup. Firewall checker works well, but the certificate is not updated. What im looking for is if its possible to manually launch a certificate update as it is a domain that was created by 3CX during the installation.
Best regards
Toby
I made some "RTFM" on the forum and find a post that helped me. there was a manual procedure for
Reactions: NicholasP_3CX
