Solved SSL certificate renewal failed
baseuser121
Forum User
Hi All,
Our phone system on dedicated windows 10 pc, and its not renewing the SSL. I keep getting failed notification.
Currently 3cx is on
Version Number16.0.16
Any help is appreciated
I thought of doing that but I am unable to get v18 for windows. They have removed the link from my customer portal for everyone
I was having the same problem with my 3CX v16 installation (v16.0.8.9) and installing the update to v16.0.8.16 fixed the problem.
You show a straight v16.0.16 not v16.0.8.16. Is that just a typo?
Hi @baseuser121 ,
We have recently updated the Customer Portal and from what I see in the screenshot, you are seeing the old version of it.
Try to explicitly log out of the Customer Portal, then clear your browser cache, or even try to use an Incognito Window.
The find your license key, click on it, press "Install" and you should get the option to press "Self-Managed" and download it from there:
If you have any trouble let us know.
Thank you
Hi @baseuser121 ,
Thank you. This has now worked.
Reactions: NickD_3CX
Yes you are right. After the V16.0.8.16 it automatically fixed the issue., Thank you
This issue has now been resolved. Thank you everyone
