SSL certificate Screwed
paul@pcjen
New User
I've managed to screw up adding a new SSL certificate so I can;t access the dashboard via the secure page, how can I rectify this
What OS?
You should be able to fix the SSL by replacing the files with correct ones, then cycling the nginx service.
Thank you for your response, I'll give that a whirl!! Win 10 Pro
Then you'll want to replace the files here: “C:\Program Files\3CX Phone System\Bin\nginx\conf\instance1” keeping the names exactly the same (phone.mydomain.com-crt.pem and similar) and then pull up services and look for the 3CX nginx service to restart.
Thank you so much for your assistance
Jeremy Hofex
