Solved SSL renewal failed
ke5jzm
System.BadImageFormatException: Could not load file or assembly 'BouncyCastle.Crypto, Version=1.8.10.0, Culture=neutral, PublicKeyToken=0e99375e54769942'. The module was expected to contain an assembly manifest.
File name: 'BouncyCastle.Crypto, Version=1.8.10.0, Culture=neutral, PublicKeyToken=0e99375e54769942'
at PostInstall.CertificateUtils.PemToDer(String pemContent)
at PostInstall.CertificateGenerator.GenerateCsr(String domainName, String rsaPrivateKeyInPemFormat)
at PostInstall.CertificateGenerator.CreateCertificateKeyAndCsr(String domainName)
at PostInstall.CertificateGenerator.ProcessCertificatesDirectory(String directory, Boolean temporaryCertificateGenerated, Int32 regenerateNotSelfSignedCertificatesFrom, Int32 regenerateNotSelfSignedCertificatesTo, CloudServerStatus statuses, Int32 regenerateCertificateExiredInDays, String appBin, UInt16 sipPort, UInt16 tunnelPort, Nullable`1 httpPort, Nullable`1 httpsPort, Boolean isPassiveFailoverMode, Boolean enableDnsHelper)
at PostInstall.CertificateGenerator.RenewCertificates(String appBin, String nginxConfigFolder, String configurationPath)
What version of 3cx are you running, please include build no
18.0 (Build 461)
There seems to be something missing in the installation that could be causing this fail.
I think the shortest route to a solution would be to:
  1. Take a Full Backup and download it to your local machine.
  2. If this is a Virtual Machine, shut it down
  3. Create a new Virtual Machine and do a new Debian installation: https://www.3cx.com/docs/manual/installing-debian-linux-pbx/
  4. Restore your backup
  5. After the installation is finished, set the new installation's LAN IP to the same IP the previous installation had, so that all IP Phones and and 3CX Apps register again.
  6. After you change the IP, make sure you click a warning sign that will appear in the Dashboard to set the new IP in the 3CX Settings too.
Reactions: ke5jzm
Worked like a charm!!! Thanks!
Reactions: NickD_3CX
Glad we could help!
Marking this one as 'solved'.
