Solved Start a 3CX Videoconference Now - SSL Error - On-Premise
support.atr.01
With the new and latest 3CX Windows Client version 16.3.0.264, we have a SSL error when we click on the button Start a 3CX Videoconference Now. This happens inside our corporate network or at home connected with a VPN. On the outside internet, no problem, the button uses our DNS.
The 3CX Windows Client opens a Chrome or an Edge browser to the private IP of our PBX in HTTPS port 5001. So the browser shows an error about the SSL certificate. Of course, our SSL certificate is bound with our FQDN.
We have a split DNS design. So the button Start a 3CX Videoconference could just use the same DNS.
I tried to manually change the Network interface for registration and provisioning in the PBX without success.
I tried to manually change the My location / In Office setting in the 3CX Windows Client Account setting without success.
Let me know what I can do, if there is another setting or if my users are the only ones to complain about SSL Certificate alerts in the web browsers.
Thank you
That client doesn't support WebMeeting v18. You must use the DesktopApp or Webclient to use it.
Also, I'd recommend switching to the DesktopApp as this legacy client will not be developed anymore (only bugfixes.)
Reactions: VasilisV_3CX
Your setup should change to a split DNS configuration whereby the internal hosts under the same FQDN resolve to the local IP of your 3CX and external client to the public IP of 3CX.
During the installation of 3CX, you can set this config behaviour and it is becoming the only supported way in the future for all 3CX installs.
Hi StefanW,
Our installation is using split DNS since 2017. In fact, we have two 3CX On-Premise in two different buildings. They are connected with a 3CX bridge. This is perfect for the company. In the second 3CX, I get the same exact result.
The button Start a 3CX Videoconference Now use the internal IP with HTTPS, so we go directly to an SSL error in Chrome and Edge. Of course, we can accept the risk and reach the Web Conference hosted on the PBX. This happens only when the 3CX Windows Client version 16.3.0.264 detects that we are inside the building.
As ConceptsWeb told me, the new 3CXDesktopApp version 18.8.508.0 is working fine. No issue at all.
Is this situation is normal? Is there a workaround? Am I missing something?
Thank you
When you see in the client provisioning settings an internal IP, then you may have managed the FQDN in your network correct but 3CX still "thinks" it should tell internal clients to use an IP.
Please check (BUT DONT CHANGE)
Settings --> Parameter -->
  • WEB_ROOT_LOCAL
  • WEB_ROOT_EXT
  • WEB_ROOT_LOCAL_SEC
  • WEB_ROOT_EXT_SEC
Both On-Premise 3CX PBX have DNS inside those parameters
WEB_ROOT_LOCAL --> DNS
WEB_ROOT_EXT --> DNS
WEB_ROOT_LOCAL_SEC --> DNS
WEB_ROOT_EXT_SEC --> DNS
I've included a screenshot of the actual configuration.
I tried to "Regenerate provisioning file" after double-checking those parameters but I get the same result. I even tried to delete and re-import the new provisioning file without luck. Just to help the operating system of our clients PC is Windows 10 Pro 20H2 x64 French.
Thank you
Thank you
To make the 'legacy' client use the FQDN for both internal and external communication, edit the Extension and in the Phone Provisioning tab, in the Network Interface drop-down select the FQDN and press OK.
After this, Exit the 'legacy' Windows Client and re-launch it so that it "pulls" the new settings.
Now if you check in the Account settings, you should see the FQDN for both local and remote fields.
Also the WebMeeting should open with the FQDN.
Hi NickD_3CX,
You're right. In my first attempt to switch the "Network interface for registration and provisioning" I did not completely closed the 3CX 'legacy' Windows Client. I just tried to use the "Re-register".
Our installation(database) is from 2016. So it's probably why everything was set to the IP. Now, when I create a new user, this "Network interface for registration and provisioning" is automatically set to our "Split DNS"
That's exactly the source of this situation.
Excellent! Problem solved! I knew there was a little something that make me fall in between.
Thank you very much
Reactions: N_G and NickD_3CX
Graham Robertson
