StartUP Default Music on Hold
Rsztd
Hello, do you know where can I download the StartUP Default Music that is played when call is on Hold ? Also if it possible to change it ?
Hi @Rsztd
You will need a StartUP Pro to change the Music on Hold but is only for the queues.
You navigate to Call Handling>>Select a Queue>>Options and you can upload or record your own Music on Hold.
Please also find the StartUP guide below https://www.3cx.com/docs/startup/
Hi Nikolas, Team
So even if you have StartUP Pro you cannot change the Music on Hold for a call that is just put on hold?
Darren
Ah. Bummer.
Netflo
