Startup Free
alcastel
Trial User
Hello, I am not able to create a Startup Free instance.
The only instances I get are Startup PRO with two months of free trial, as you can see below.
Do you have any hint about how to create a FREE instance?
All StartUP start out as Pro and then it downgrades after 2 months if you don't buy a Pro license.
Yes to what @SteveITS said. :) We offer StartUP PRO completely free for the first 2 months so you can test all the features StartUP has to offer.
At the end of the 2-month trial if no purchase is made, then it will auto downgrade to 3CX StartUP FREE, which has no expiration.
Just something to keep in mind: If you have configured any PRO features during your trial period please note that those may no longer function after the downgrade. You can check out the differences between the 2 here.
Best Wishes,
Monika
Reactions: KaterinaK_3CX
sherry reynolds
