Status not changing after a call
Novum Live
SOHO User
Hi All.
I'm using 3cx Hosted v20 Pro 4SC
On the PWA client using Chrome on a Windows 11 laptop, after taking a call, stsuses are getting stuck in DND or On A Call.
We then have to manually change these back.
It happens more with PWA > PWA client calls than with external or [physical handset calls. However, it does happen on all.
Any ideas on how to fix this?
Many thanks
A user status wouldn't normally change to for instance DND when in a call, it's a manual change. Are you syncing to, say, Teams?
Reactions: KyriacosS_3CX
Yes. Team is synce'd. Teams is showing avialable but when I come off the call the status on 3CX is still showing red "On a Call".
Red is DND, yellow on a call. Check you Teams sync.
Re-doing teams integration might be needed, as it seems something there has fell out of sync. Perhaps the community has from experience some other things you can try.
Thanks All.
I do have trouble with Teams sync also. It keeps struggling to stay in sync! So I'll look at this.
Thank you for your help.
