Solved Status SYNC issue with Yealink firmware version 96.86.100.5
Wunan
Yealink T54W DND status is not syncing with the server with 96.86.100.5 firmware version. When I downgrade to version 96.86.0.70, it works perfectly.
I tried turning off and on the "key_sync" feature as well. Nothing works.
Need solution to this URGENTLY.
Thank you.
georgi
