- Joined
- Jan 1, 2023
- Messages
- 47
- Reaction score
- 2
I always have a problem with a stun and I want to know the right configuration, please
I have 3 Yealink phones at the customer place and my 3cx hosted on AWS
in 3cx configuration, i use the following
1st Phone
Local SIP Port 5065
Local RTP Audio Ports Start at 14000
Local RTP Audio Ports End 14019
2nd Phone
Local SIP Port 5066
Local RTP Audio Ports Start 14020
Local RTP Audio Ports End 14039
3rd Phone
Local SIP Port 5067
Local RTP Audio Ports Start 14040
Local RTP Audio Ports End 14059
Now on AWS side I add the following protocols with the following ports.
is this the write configuration for stun
Thanks in advance
1st Phone
Local SIP Port 5065
2nd Phone
Local SIP Port 5066
3rd Phone
Local SIP Port 5067
| Custom TCP | TCP | 5065 | the static ip address of the PBX |
| Custom UDP | UDP | 5065 | the static ip address of the PBX |
| Custom TCP | TCP | 5066 | the static ip address of the PBX |
| Custom UDP | UDP | 5066 | the static ip address of the PBX |
| Custom TCP | TCP | 5067 | the static ip address of the PBX |
| Custom UDP | UDP | 5067 | the static ip address of the PBX |
Thanks in advance
