Swapping of Licenses
seawyk
New User
hi
I am currently running two different instances of Debian 3cx
Office - 3CX Standard
Home - 3CX Pro
The office is planning to sign up for a Pro subscription and i would like to transfer the existing standard licence from my office instance to my home instance
Any idea how i should go about doing this?
@seawyk
Can you clarify:
Do you mean to move the existing system installed with a standard license from your office to your home?
Or
Are you referring to replacing the license key option?
Also, please clarify the following:
Office - 3CX Standard - is it paid standard subscription or a free edition?
Home - 3CX Pro - is it paid subscription or a free trial?
@seawyk
Can you clarify:
Or
My office is now using a 3cx standard free edition. We are planning to upgrade this license to a pro license
My home is using a pro trial license.
I want my home to take over my current office standard free license
I want my office to upgrade to a paid pro licence
Hope this clarifies
Hope this clarifies
Just upgrade the office Standard to Pro.
Then let your Pro trial expire and it will revert to free (if the key was created before January 2023, IIRC.)
Reactions: IrinaP_3CX
The pro trial key was created after Jan 2023
Any impact?
Any impact?
Yes, no more standard for free.
You'll need to sign up for Pro with a new key and FQDN, then reinstall your home with the existing key (you can release and get a new FQDN if need be)
@seawyk
Trials created after Jan 2023 expire after two months and your PRO trial may have expired.
You can check the status in your 3CX customer portal, or reach out to our Customer support team via live chat from our website/via contact form to check the current status of your trial for options.
Jake_Southern
