Swedish language
ArtoSkogman
Hi! Is there away to translate the web client into Swedish language? There is laready Norwegian, which it is quite close. If we do it by ourselves, is there some language pakcet?
Hi @ArtoSkogman,
What you'd need is a Gold Partner or above to post this to the Ideas Forum on your behalf. If the Idea gains enough traction it may well be considered for implementation.
Ok. Thank you.
