System Owner Disable Presence
tony28
Forum User
How to disable system owner from showing presence to group members?
Hello @tony28
It should be done via Management Console -> Users, click on the user which is System Owner -> Rights and adjust accordingly.
Make sure show presence is unticked in order to hide their presence in the group.
Regards,
Monika
Its grayed out ....
@RJansen
Yes, it is greyed out for me because I am accessing the console with an extension which is not a system owner.
The System Owner will see the options correctly and will be able to tick and untick as needed.
Regards,
Monika
First, I apologise for my confusion.
Let me explain it in more detail:
Group Owner, Group Admin, System Owner & System Admin rights are pre-defined and cannot be changed.
When you log in to the console as a System Owner, you can adjust the rights for the Receptionist, User and Manager extensions.
Regards,
Monika
Jeremy Hofex
