system status CPU graph
Chris Ruffin
Is there a way to configure the system status graph on the dashboard to more than the last 25 seconds? I would like to get a more long term profile of CPU load.
We are using third party software monitoring tool (zabbix, prtg) and snmp. But you need additional machine for that monitoring software.
Not inside 3CX. You have to use another means outside of 3CX for that. The instance manager records for longer but with less granularity. If it's a VM then typically the host has CPU monitoring capabilities.
Reactions: NickD_3CX
jmarshall
