- Joined
- May 4, 2020
- Messages
- 33
- Reaction score
- 7
I know there are a ton of articles on this forum about T.38 faxing but I'm have a devil of a time getting it to work consistently. We use Telnyx as a SIP provider which supports T.38. I have all of the parameters set correctly on their side per the configuration guide. But they are saying the 3cx server is not sending a T.38 re-invite. I've tried many different configurations including turning off the "Enable G.711 to T.38 Fallback" box (and restarting the IVR service after the change). Do I need to check the box under the SIP trunk options that says "Supports Re-invite"? The how to guide suggests that i should leave that disabled. Incidentally, I've tried it both ways and it doesn't seem to matter. Any suggestions?
