T43u Line Keys
tikom
Hi everyone,
I hope someone can help me with this issue.
I have a Yealink T43U for a customer who has 4 concurrent channels. I configured 4 BLF keys for him, each as a line key. When I press any line key, I can make a phone call without any problem. However, when I receive 3 or 4 calls at the same time, only the first line key works.
For example, if I have a call on line one and another call comes in, I need line 2 to ring. If both lines are busy and a third call comes in, I need line 3 to ring.
How can I achieve this?
Thanks in advance.
Hi there.
Yes, but in your case, you need to answer the call first right so that setup can work?
So you will answer the call, then for example park the call etc?
ok
how can I enable all line keys to accept concurrent calls?
This is the device settings about the lines, as 3CX simply send the call there, and it accepts it.
Finatra.us
