T88W Pro
SAV.IB
Gold Partner
Reactions: robsonh
Hi, we don't have details on when or whether phones will be added. As phones are added, they will appear in the supported phones section and under the Blog section.
I hope 3CX will quickly integrate the T88W (perhaps in the final Update 8), as Yealink stopped producing the T58W last December and the T88W is its replacement.
Kind regards,
Alain.
I've just get one Yealink T88V, and it isn't support yet :(
I will try with T58V firmwere.
Yealink partner support for 3CX seems that it should work - look below?
Reactions: robsonh
Not sure if it was a typo, but:
Putting a different model's firmware on the phone is, in general, a bad idea; the phone should reject it, but my feeling is that it is asking for trouble, possibly a bricked phone.
If you meant provisioning it with a different model's template, that's different; still many unknowns, and I wouldn't recommend it, but at least you're not trying to brick the phone ;)
Reactions: bitn2
Just adding some feedback here.
In the last week, we have been asked three times for this phone on 3CX. I can see why, its a great executive phone. Hope we can see it added soon!
Reactions: robsonh
I used provisioning T58V with T88V Pro and it works! - T58W Pro is almost EOL, we had a problem with T58W Pro Handset (there is no handset in oficial market).
With firmware I'll wait ;-)
Yealink T88V Pro works better then T58W, so 3CX You Should support Yealink T88V Pro and T88W Pro
Did it work as a router phone? I'm being hounded for the T88 phone here!
+1
We would really appreciate this ASAP.
Did it work for all features? Or were some not working?
I contacted Yealink about this, and they have responded saying:
3CX has confirmed that they will no longer certify new Android-based models, therefore the T88W will not be able to obtain 3CX certification.
Is anyone at 3CX able to confirm whether this is correct? We're getting lots of requests for this phone and it's a shame if this is true.
I think that this is a definitive answer...
I tried building a custom template. Got the phone to register but not the SBC on the phone, so no precense etc. Has anyone had more success? If so can you share the firmware version?
Reactions: robsonh
Hello, I tried this also but ran into the same issue. I think that we need 3CX firmware in order to get it to work.
It works almost perfect with as T58 - but You are absolutely right - 3CX should prepare firmwere!
Same for us.
The Yealink T88W Pro phone, which has a Bluetooth cordless handset, hasn't been validated by 3CX.
Since Yealink stopped selling their Yealink T58W Pro phone, we're stuck.
Do you have any projections for when this phone will be validated?
Reactions: NDT
cvanderzwan
