- Joined
- Aug 13, 2024
- Messages
- 1
- Reaction score
- 1
We have a fully working Teams Direct Routing integration with 3CX. Regular inbound and outbound calls are functioning correctly. However, emergency calls (911/933) from the Teams client are failing with a 415 Unsupported Media Type error returned by 3CX.
- 3CX V20.0.8.1131 hosted on Linux
WHAT HAPPENS
When a Teams user dials 933, Microsoft Teams identifies the call type as ByotOutEmergency and sends a SIP INVITE containing Content-Type: multipart/mixed with both SDP audio negotiation and PIDF-LO location data in the body. 3CX returns a 415 Unsupported Media Type response, rejecting the call.
MICROSOFT TEAMS ADMIN PORTAL DIAGNOSTICS CONFIRM
- Voice Route Matched: 3CX Voice Route
- Call Type: ByotOutEmergency
- Customer SBC Matched
- Final result: 415 Unsupported Media Type
- Microsoft subcode: 560415
WHAT WE HAVE CONFIRMED
1. Setting PidfLoSupported = False on the Teams gateway does not prevent Teams from sending PIDF-LO on emergency calls. Microsoft forces PIDF-LO on ByotOutEmergency call types regardless of gateway settings.
2. When the call accidentally connects without PIDF-LO, it routes to the national PSAP registry instead of the correct local PSAP because no location data is delivered to Bandwidth.
3. All non-emergency calls work correctly — the issue is isolated to emergency calls only.
4. PidfLoSupported is currently set to True on the gateway as this is the correct configuration for E911.
Can 3CX be configured to:
1. Accept multipart/mixed content type in SIP INVITEs on the Teams trunk for emergency calls
2. Pass through the PIDF-LO location data to the outbound Bandwidth ESIP trunk so Bandwidth can route to the correct local PSAP
3. If PIDF-LO passthrough is not supported, what is the recommended approach for E911 with Bandwidth when using Teams Direct Routing?
WHAT HAPPENS
