Solved Telnyx - Anonymous Caller ID Issues
HLM 3CX
Platinum Partner
Dear 3CX Community,
I'm running into an issue terminating *5 (*67) blocked calls through Telnyx.
Per their documentation on "How to Anonymize Caller ID Number" the PBX should do the following.
1) Set the "Privacy: id" header
Per the SIP trace I can see that 3CX is correctly setting this flag on invite - you can see it set below.
2) Set the "From" header to "Anonymous" <sip:anonymous@anonymous.invalid>;tag=12345-6789"
I believe this is what is causing the call to fail, due to how 3CX is formatting the invite. It is not anonymizing the domain port part of the URI.
My understanding is that Telnyx is fully supported and certified by 3CX; so I don't understand why this is not working. Do I have to change a setting 3CX that is not being disclosed by Telnyx's documentation.
Can someone with a Telnyx trunk confirm if you can hide your Caller ID by dialing via *5 (*67)
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 3CX.LOCAL.IP.ADDRESS:5060;branch=z9hG4bK-524287-1---974986054367387d;rport
Max-Forwards: 70
Contact: <sip:3CX.PUBLIC.IP.ADDRESS:5060>
To: <sip:[email protected]:5060>
From: "anonymous"<sip:anonymous@SIP.PROXY.IP.ADDRESS:5060>;tag=9630c676
Call-ID: d4k3UIH4xfW4nh1MMUggFA..
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO, MESSAGE, UPDATE
Content-Type: application/sdp
Supported: replaces, timer
User-Agent: 3CXPhoneSystem 16.0.8.9 (9)
Privacy: id
Content-Length: 234
Thank you for your time.
Hi @HLM 3CX
Try changing the From: UserPart to the value shown below and let me know if that works. Leave everything else as they were in the default template
YiannisH_3CX
I appreciate the quick response, and you knowledge!
Your suggestion has resolved the issue on my end and I can now send anonymous dialing via *5 / *67.
Looks like the documentation provided by Telnyx is no longer relevant.
Thank you.
Reactions: YiannisH_3CX
Glad i could assist. We will do some more testing and update the template as needed.
lastshadow
