Solved Telnyx blocking anonymous outbound
Chris Walters
Platinum Partner
https://support.telnyx.com/en/articles/3546251-caller-id-number-policy
When using the default *5 dial code to block outbound caller ID, I get this response:
192.76.120.10 replied: 403 Caller Origination Number is Invalid D35; from IP:192.76.120.10:5060
How can I alter the SIP headers the way Telnyx describes in their documentation to allow for anonymous outbound calling?
Hi @Chris Walters
If you set up the trunk as described in our guide then you should not have to do any changes to the trunk settings.
Reactions: YiannisH_3CX
Hi @Chris Walters
Hi @YiannisH_3CX ,
Thanks for the response. I checked through that guide and everything was properly configured, default template in use with credential authentication.
Adjusting the From: User Part as described in my post above resolved the issue.
Glad to see you were able to resolve the issue. We'll check it out
Syedx91
