The export customers CRM integration from 3CX system to PC as xml configuration file.
Alcasys
Pleas, how is possible make export CRM xml configuration file from 3CX system to PC desktop ?
Thank for help
Petr Halberstat
Just copy the XML.
It won't contain the configuration tho, only the definitions.
Reactions: edossantos
Yes, and where is storage of CRM xml file in system for possible of download ?
Simply click "Show template" in the CRM settings page.
Thank you, only copy from opened template.
Thank you very much
Robert Lee
