Time Zone GMT ID to be used as ID
sergio.londono
Platinum Partner
Good morning community,
I have an 3CX ippbx with extension in different time zone, my idea is to setup the time zone in GMT however there is not ID for time zone GMT.
http://www.3cx.com/wp-content/uploads/2016/11/Time-Zone-Sheet1-1.pdf
I noticed London, Portugal, Ireland and Denmark have time zone 0 however in summer time the time for those countries change.
Do you know what ID can I use to setup GMT, the time can't change based on winter or summer time.
regards,
What version of 3CX are you running, I have just checked in ver 16 and there is a GMT time zone
Not sure if this is what you require
The version I am using is: 16.0.493, I am not doing it using the Wizard first setup,
I am creating the the PBX using the XML upload option.
Which ID is associated with GMT?
Even, with the wizard, doesn't any entry for GMT
You can use the London timezone, its Greenwich Mean Time with no DST
Ok, Perfect, I will use that TIme zone.
Thanks,
Ravex comms
