Top Tips for Video Conference Server Optimizations
NickD_3CX
Community Manager
3CX Video Conference in V18 breaks ties with its predecessors and relocates a lot of its data warehousing into your 3CX System. This sets a new standard for privacy, safeguarding your own data and that of your attendees. In order to properly cater for this shift, here are a few tips for admins to take note.
Use default HTTPS port 443...​
Hi Nick,
Thank you for this very well written article!
I would like to get a little more detail on this information:
Note: “Split-Brain DNS” setups will become mandatory in 3CX Systems in the future.
We are currently working with "local DNS" for physical phones.
Does this mean that 3CX is considering dropping the ability to add "local DNS" choice during installation? .
thx
Reactions: NickD_3CX
Hi Nick,
thx
No, it just means you will need to use an FQDN locally with Split DNS to have everything work correctly.
Merci @ConceptsWeb de ta réponse mais cela ne répond pas à ma question.
Vous m'expliquez qu'il faudra remplacer 4 pièces de 25₵ par une pièce de 1$ mais là n'est pas la question.
( Et si nous, nous préférons 4 pièces de 25₵ ? :p lol )
Quand est-ce que tu joins ton expertise au notre ?
Ont a bien besoin de toi et ton expertise !!
L'offre de nos dirigeants tiens toujours :D !
My question is... will we be able to choose to continue working with a local DNS instead of Split DNS (New deployment).
There are many reasons why we don't work with a SPLIT-DNS solution.
We have already tried to work with this method and we encountered different problems in different non-Windows DNS server.
Thx
Guillaume
Dear @bravad , the option to enter a local DNS entry will be removed in the future versions of 3CX.
It should also not make a difference to use a different DNS server as long it responds locally to the "3CX FQDN" with an internal IP.
Can you tell me which DNS server you use so that we can make a guide for it?
I would assume bind would be an excellent addition to write a guide for.
Some firewalls also allow responding to some DNS queries. For example, pfsense has a "special" setting for SplitDNS setups
https://docs.netgate.com/pfsense/en/latest/services/dns/resolver-host-overrides.html
Bonjour Nick,
Les limitations sur le nombre de caméras pourront t'il être levé avec une instance on premise ? Si oui, des pré requis matériel sont ils à prévoir ?
Hello Nick,
Could the limitations on the number of cameras be lifted with an on-premises instance? If so, are any hardware prerequisites required?
The limit of the concurrent active video streams is something we due to the clients, not the server. Having many video streams on a clients/participants PC can put very big strain on their hardware, and we all know that end-users don't always top-of-the-range hardware.
There is also the matter of bandwidth which again increases the more video streams are active.
We are constantly looking at ways to improve WebMeeting though, so if anything changes we will be releasing a blog post about it.
To answer your questions though, currently I have no information about the on-premise MCU allowing more video streams, but it has not be released yet, so we'll have to wait and see!
Hassan Murasan
