Total number of External Calls Report
commsbyte
Is it possible in V20 that you can devise a report showing the total number external calls made.
At the moment you'd have to export a call log and then use filters and forumlas in excel.
may be quicker to export a call cost by ext dept?
You can get this information from the CDR files. Depending on how easy/hard it is to access those files (depending on where your PBX is hosted), that might be a straightforward way to automate the process.
Our 3CX Exporter tool can automate the entire process for you, and we will write the report for you.
Graham Robertson
