Trialling V16 Alpha With PBX Express
Wendelspanswick
I was going to take a look at V16 by using PBX Express to install it on a free (for 1 month) Amazon Lightsail instance, does PBX Express give you the option of which version of 3CX to install?
Anyone?
I've taken PBX Express up to the point where you click OK to create the instance using an old V14 NFR license (Not For Resell) but at no point has it given me the option to select V16 Alpha
@Wendelspanswick
You can install the stock 15.5 sp6 version through PBX Express and, presuming you're using a linux install, update to V16 alpha 2 from the update menu.
Reactions: Wendelspanswick
For installations to instances you own PBX Express will install the latest stable version which is V15.5.15502.6. For free trial instances the PBX Express will install V16 Alpha 2.
BIT Incorporated
