Trunk simultaneous call count increase not working
treefiddy
When I created this trunk (Centurylink) initially I had it set for 30 simultaneous calls and have now increased the value. The problem is that when I test sending more calls to that trunk, it still only accepts 30 calls. Has anybody else experienced this?
I have restarted the host multiple times which is v15.5 on Windows.
Have you tried simply recreating the trunk?
Does the Activity Log show 3CX blocking more than 30, or, perhaps, the provider? I assume that they allow more than 30.
I actually haven't tried recreating the trunk. It's worth a shot though, so I'll try it.
EDIT - No I won't. That will delete all of my DIDs and the export doesn't handle DIDs or even all of the settings for the trunk.
Yes I increased the limit in the provider as well.
Does your 3CX licence allow you to perform more than 30 simultaneous calls? Check your activity log and see what error you are getting when the 30 calls are reached.
Reactions: leejor
fransisco
