Trunk to Trunk connection
Steffen Maier
I have a Trunk für a Phone system and a sub-pbx.
To get incoming calls from one trunk outbound to another I have set rules.
But now I get error messages like:
Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
But the trunk is set to IP Based, so creditials cannot match.
Is this because it is a trunk to trunk connection?
That would maybe be a workaround, but could you please still try to answear the question?
Well Credentials don't match does not make a lot of sense unless you are using authentication username and password to connect.
Perhaps its talking about incorrect IP's ? but I would doubt it very much you would need to capture the full trace to be able to understand the issue properly.
megalmazan
