Trunk's Default Route via API
Tom R
Platinum Partner
Is it possible to pull the SIP Trunk Default Route from the API?
I have explored the documentation but can't seem to find it.
  1. Which API and from where?
  2. 3CX API in the 3CX per CFD App or call script?
  3. 3CX configuration API via web request?
  4. Where is the 3CX hosted?
  5. How have you access to it?
  6. What is the purpose of the query?
3CX configuration API via web request, with a system owner user authenticated.
I need to be able to pull the default route so I can audit and report on call routing
powershell example for a single trunk:
Code:
$uri="https://$tcxurl/xapi/v1/Trunks(1234)?`$expand=RoutingRules(`$select=Id,Condition,Data,OfficeHoursDestination,RuleName)"
((Invoke-RestMethod -uri $uri -headers $headers -Method GET -ContentType "application/json").RoutingRules | Where { $_.Condition -eq "ForwardAll" }).OfficeHoursDestination.Number
you should know the specific trunk ID or get all in a loop and select it by name there
Reactions: jed and Tom R
Code:
Thanks. This is working!
Reactions: fxbastler
BConveryCoreCare
