Tunnel Port Change
Jörg
is it possible to change to 3cx tunnel port (default 5090) to something else, like 80, to bypass restrictions that are applied in some public networks? And if yes, where is the port configured? I am using 3cx on Google Cloud.
Best Regards
Jörg
Hello @Jörg
Please note that you can select a different tunnel port only during the installation procedure. If the PBX is already installed you will need to re-install it in order to be able to select a different port. PBX Express however will always use the default ports.
@Jörg
So I'm not really aware of any "public" networks that block outgoing traffic. Many secure private networks but not public that I've seen. And if you do come across a public network that is locked down that tight I'd imagine they also inspect at the protocol level so attempts to send tunnel traffic out via the HTTP port will fail anyways. Have you actually had a case where the tunnel traffic was stopped/
zipman
