Solved turn down volume on hosted inatnce
BABALUCHA
Hello Everyone
Thank you for stopping by and pitching in for this, wanted to turn the volume down on the 3cx hosted instance . Thanks a lot in advance.
Turn the volume down on what? Calls? Music on Hold? Something else?
Reactions: BABALUCHA
Can you please be more specific?
That’s dependent on the WAV file. We downloaded and reduced volume on the default WAV file, and reuploaded it, to match others we upload.
Thank you so much for the help, I like the idea. Thank you :)
Reactions: SteveITS
Typically, any custom music on hold needs a volume reduction of 30%ish (your figure may vary) from normalised so as not to be deafening / distorted to the caller.
@BABALUCHA
Great and thank you for the feedback.
DrunkeMeister
