U.K Emergency services number not in service
Michael.puttock
Forum User
Hello all,
I'm hoping somebody can point me in the right direction, we had a BT SIP line installed just before Xmas which connects to a Beronet VOIP gateway and then to 3CX.
When emergency/Non-emergency numbers are dialled they are greeted with a "Number you have dialled is not in service" message, 999 and 101 are both set in the PBX for emergency numbers.
I have updated Debian and 3CX to V16 and also updated the Beronet box to the latest version.
If you need any logs etc. let me know.
Much love!
Have you changed the Voicemail number? 999 is the default on 3-digits systems.
Reactions: AWS2P
Is the call going out to the SIP trunk? if yes, what digits are being sent?
What routing have you got your emergency numbers going to?
Make sure 999 and 101 are not system or user exts.
Hi Michael,
For UK localizations, 666 becomes the voicemail, and 999 is free for accessing emergency services.
You must also Configure the Emergency services to match your Extension Group (mine is called linux in this example) and also select a route that can make that call:
So far so good, you now have to check your activity log to see if the call is being completed
Hi all thanks for your replies.
JohnS_3CX - Thanks, I also have the same as you already set up.
kieferschild - yes the call does go out towards the beronet box. The emergency numbers are routed to the beronet also.
I will get some logs from the Beronet, I'm wondering if the "number is not in service" message is from BT themselves.
Reactions: JohnS_3CX
Yes go ahead, I don't think the PBX has such a message in the Prompts.
Ensure from the Beronet logs that the gateway actually calls the intended number when dialling on BT network. If it actually is, then talk to them about it for confirmation
Please see the below logs from the Beronet, External calls look the same too but they do work.
=== CDR,1,SIP:10.0.2.10,ISDN:1:1,"10000" <sip:[email protected]>,"" <sip:[email protected]>,10000,101,17/01/01-23:03:16,17/01/01-23:03:23,17/01/01-23:03:16,17/01/01-23:03:23,SIP,NUA_I_BYE:200,-,-
<== I RELEASE|INDICATION|CID=00001
cause=16 (Normal call clearing)
==> I DISCONNECT|REQUEST|CID=00001
out_cause=16 (Normal call clearing)
<== S BYE|INDICATION|CID=00001
<== I CONNECT|INDICATION|CID=00001
<== I SETUP_PROCEEDING|INDICATION|CID=00001
==> I SETUP|REQUEST|CID=00001
port=1, channel=1
dad=101, dton=4
oad=10000, oton=4
=== D INCOMING:CID=00001
SIP=>ISDN, from_id=d:SIP-ISDN-Extern-BRI, to_id=g:ISDN-Extern-BRI, line=3
new_src=10000, new_src_auto=10000
new_dest=101, new_dest_auto=101
<== S INVITE|INDICATION|CID=00001
from_user=10000
from_display=10000
to_user=101
request_user=101
contact_user=10000
The posted log seems to involve extension 101, but there is no indication of a dialled external number. Confirm, using the 3CX Activity Log, that the number(s) are actually being sent. (the call leaves 3CX) Compare a "normal" call, and a call to the emergency number(s). Perhaps the numbers are being screened/modified/blocked, using a dial-plan, in the gateway.
The logs from 3CX show the call:
03/03/2020 3:53:16 PMUser (231)10100:00:07
Below are logs from the Beronet when calling an external number (Removed last 3 digits) which works fine.
=== CDR,2,SIP:10.0.2.10,ISDN:1:1,"10000" <sip:[email protected]>,"" <sip:07732032***@10.0.2.11>,10000,07732032***,17/01/01-23:32:16,17/01/01-23:32:25,-,-,SIP,NUA_I_CANCEL:200,-,-
<== S CANCEL|INDICATION|CID=00002
<== I PROGRESS|INDICATION|CID=00002
<== I SETUP_PROCEEDING|INDICATION|CID=00002
==> I SETUP|REQUEST|CID=00002
port=1, channel=1
dad=7732032***, dton=2
oad=10000, oton=4
=== D INCOMING:CID=00002
new_dest=07732032***, new_dest_auto=07732032***
<== S INVITE|INDICATION|CID=00002
from_user=10000
from_display=10000
to_user=07732032***
request_user=07732032***
contact_user=10000
Can you send a screenshot of the dialplan page?
Please see the Dialplan page below, thanks for all your help - this was all set up by a previous guy who left no notes so I'm a bit out of my depth.
If you make a rule for the speaking clock (123) to go out the beronet and try calling that, are you getting the same thing?
Left work for the day so I'll test that tomorrow - Thanks Kieferschild
Your dial plan looks exactly line mine btw.
What does the Beronet log , for a call that is failing, look like?
Lengo
