Un-sync Office 365
IZT_crobinson
I set up to Sync with O365, which ended up syncing the operator extension. I unticked sync and it removed the "Synced with" on the Extensions page for all extensions except 2. The operator and 1 other user.
I tried rebooting/restarting services with no luck.
The operator cannot be deleted. But, you can define a new extension to be the operator, then delete and recreate the old one. Once done, you can set them as the operator again.
swegner
