Solved unable to add a phone - auth fail, but pwd is correct
vradmin
I'm trying to add one phone to our 3CX.
It works as usual if I use the windows client.
But the Granstream 1630 phone is unable to authenticate.
I have 4 other phones of the same type, but this one wont work :(
What can I do, other than bang head to the wall?
The 3CX log entry:
Code:
08/09/2018 4:35:13 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 1.2.3.4:5069 tid=1726684536 [email protected]: REGISTER sip:voip.vrvoip.it:5260 SIP/2.0 Via: SIP/2.0/UDP 1.2.3.4:5069;branch=z9hG4bK1726684536;rport=5069 Max-Forwards: 70 Contact: <sip:[email protected]:5069>;reg-id=1;+sip.instance="<urn:uuid:00000000-0000-1000-8000-000B82CCC6C1>" To: <sip:[email protected]:5260> From: <sip:[email protected]:5260>;tag=1931814956 Call-ID: [email protected] CSeq: 2002 REGISTER Expires: 3600 Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE Proxy-Authorization: Digest username="2056",realm="3CXPhoneSystem",nonce="414d53595b6c511936:0ff42b6a42b7e67d443de8bf3245f89c",uri="sip:voip.vrvoip.it:5260",response="959f3812ec3faa88b321c7ee8e221ad6",algorithm=MD5 Supported: path User-Agent: Grandstream GXP1630 1.0.4.67 X-Grandstream-PBX: true Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
Hello @vradmin
Are you using the provisioning link from 3CX to provision the phone or are you trying to register the phone manually to the PBX? Also is the phone local to the server or remote?
That particular extension was bugged somehow.
I had to delete it altogether and create a different one.
Glad to see the issue has been resolved and thank you for updating the thread with your solution
Bluebox Global
