- Joined
- Jun 13, 2019
- Messages
- 88
- Reaction score
- 24
We have a client who refused to go on proactive management on the PBX. As a result, when some items changed in how 3CX worked in a v16 update their Let's Encrypt SSL cert was failing to renew. I got an alert about it and told them that no action meant that there was going to be a problem with the PBX. They finally 90 days later sent us some funds to work on it.
I've corrected the issue that was preventing the PBX from being able to successfully renew the cert from a communications perspective. However, the cert is still not renewing. I reboot the PBX and that is not enough to cause it to try to get a new cert. I can confirm that the network communications are successfully going to activation.3cx.com.
I tried launching PbxConfigTool -renew-certificates and that does not cause the cert to renew either.
As far as I can tell, the only way it will renew is to wait until 4A tomorrow. Seems like there should be a way to force the PBX to try to do the renewal now, but I cannot find the procedure to make that work.
Does anyone know how to force the certificate renewal process on Debian?
