Solved Unable to use Sharepoint for archive recroding
srane.sushant
Hello 3cx
I am unable to configure SharePoint for archive my recording
I created communication site in root of share point as well as added Folder but when i am trying to configure in 3cx its not showing me that site.
1732788612392.png​
Just this box appear and when i click nothing happen.
My integration of office365 and 3cx is showing ok status.
Please help to resolve this issue.
I am using V20 3cx.
Its probably looking at your default site and you are not. Does it let you run a backup or anything to it?
@Alphabetic Can you please help me how i make my 3cx to look at my site (I created communication site in SharePoint).
No it is not allowing me to save getting below error
Your folder names below should start with the existing root folder names that you see in the dialog Select Folder / Path
3CX can only look at the default Sharepoint site and not any you've made.
it will be your root site <domainname>.sharepoint.com
you have to specify folder names from the "Storage" page
getting same error.
I am global admin and has access to folder in SP.
Under location type of Sharepoint you need to select a folder. You will need to go to your root sharepoint and create a folder.
How to select folder?
When i click on
This 3 ... i get this.
Here there there is no filed to edit.
When i click this nothing happen
If you don't mind can you please mark where i have to enter folder name and in what format?
You will need to go to your root SharePoint and create a folder.
I created new communication site and create new folder inside that site.
https://mysite.sharepoint.com/sites/3cxArchive/Shared Documents/
Thank you its fixed.
arming
