Unsupported CRM? Not a problem with the 3CX CRM Template Generator
  • Thread starter Thread starter Constantinos Constantinou
  • Start date Start date
Makes sense, I see. Thanks for analyzing!
Hello guys. Can you please tell me is amoCRM supported? I see there is an instruction for amoCRM integration and it listed in official supported crm list, but its not in list of server side integration in my console.
Check above the dropdown, there will be a block you can open "Updates Available", open it and select it, then click Download.
"Available CRM Integrations (Up To Date)" is not clickable and nothing happens.​
@max amocrm ,
List of CRM's supported by 3CX updated. Soon with the release of v18, we will publish the updated documentation with the CRM Integrations that are 3CX and Vendor supported.
amoCRM will be added as a reference in the documentation on Vendor supported CRM's section.
Reactions: edossantos
[USER = 130054] @max amocrm [/ USER],
Обновлен список CRM, поддерживаемых 3CX. Вскоре с выпуском v18 мы опубликуем обновленную документацию с интеграциями CRM, которые поддерживаются 3CX и Vendor.
amoCRM будет добавлен в качестве ссылки в раздел документации по CRM, поддерживаемой поставщиком.
Dear colleagues, good evening. I would like to know when the issue of integration with amoCRM will be resolved? We may lose our partner, with whom we have been working for more than three years. The partner switched from Bitrix24 to amoCRM, but the integration does not work.
Jeremy Hofex
