Unsupported SIP trunk providers
gvsoft
After the main update we are getting to following error:
You are using Unsupported SIP trunk providers which may cause issues.
For a list of supported SIP Trunks visit this page.
Our SIP provider is not supported and is not on the list. What can we do so that the firewall works properly and ignores this error?
It's just a warning, to say you are not using a support SIP provider and 3CX will not help you if the issue is to do with the sip provider.
You can ignore the message, but you can not switch off the message.
Have you run the firewall check, and does it pass ?
Hello @gvsoft
As mentioned this is simply a warning and does not affect the firewall checker of the PBX.
WagnerFT
